Tim,
Our warranty information can be found at:
http://www.4speedtoploaders.com/order_info.htm
There could be several things that may cause the symptoms you are describing. Clutch and shifter adjustment is critical and is most times the culprit when more than one gear is involved.
Do you know how many miles were put on the transmission before you purchased the car last summer?
