Hi Jim. Our standard size tires that we install on the TKMinus cars are 235-60x15 on the front and 275 rear. Those taller tires makes it a little cramped in there. If you have the tubular fronts arms, you can go to a deeper rim. It will still rub, but in a different spot. If you have the MII control arms, the back of the rim will rub the upper arm. The easiest and cheapest fix is to unbolt the fender liner and move it back a little bit.
Nonconformist. Can't handle a real job.
