So Jeff would you be disappointed with these results? I had calculated the numbers based on orig hp and then the advertised add on hp etc and came up with around 500+ hp. The fact is the car is probably capable of doing a lot better than the driver is comfortable driving. Not so much at the drag strip but on road courses I need a little more experience. Racing slicks helped my confidence out a lot but I found out that when they let go it is already to late to do much about the situation.
Thanks for the input.
Clois
"Let's roll"
"Be part of Something Good
