Thread: Liquid Lock?
Old 07-13-2002, 10:43 AM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
May also want to squirt some oil into the cylinders with the spark plugs out and turn the motor over with the starter to oil the rings. Fuel strips the rings of oil. If you fire it up before doing this, you could damage the rings or cylinder bores.
Then add some top oil (STP, etc.) to the fuel for the remaining tankfull.
