I ran fuel line from my master cyl. resevoir to the clutch master. As my fluid turned dark and the line got soft I realized the error and bought the proper hose and new brake fluid. Since the resevoir also feeds the the dual tilton brake masters I decided to bleed the entire system. Brakes bled no problem... However I can not get any fluid into the clutch master. With the bleed open{out actually} I can not even blow air through the hose into the cyl. The piston moves easily since it has no fluid but regardless of piston position it will not allow any fluid in. Everything worked great before I changed the hose and had no problem filling the system the first time. I hope I'm missing something simple
