A fella on FORDMUSCLE.COM gave me a pretty good idea, he uses a late sixties early seventies ford smog pump, the type that has two holes in the back of the aluminum case, the stock fittings can be removed and threaded to use earls or russells fittings, he runs the outlet to a moroso catch can, about $50.00 and the inlet to either the valve cover or intake. NAPA list the smog pump at about $50.00. Justa6 is right, any vacuum assist in the crankcase is a plus.
Perry
