You just need to completely disassemble the carbs, dip them in carb cleaner, glass bead blast every little piece, send the steel screws out to be plated, chromate dip the aluminum parts, then put it all back together with new gaskets and such. I used to charge $600 to do a set of three two barrel holleys.
