Thread: vacuum pump
Old 07-15-2002, 03:43 PM
justa6 justa6 is offline
Default Fixit
Check the "view my photo gallery" picture all the way on the right side and you'll see a Weaver Dry Sump pump. I run the Dry sump system with no problems on the street. The dry sump will pull a vacuum if you seal the valve cover vents. And your absolutely right the oil has to go somewhere. I plan on making the vent set up on top of my oil tank with a setup that will allow the air out but return the oil to the tank. Possible?
Also as Jack has said before you should have some method to regulate the vacuum so its not too much. By the way Jack great numbers on Torque and horsepower. How many cubic inches?
Regards,
Bob
Johnex Cobra, Buick V6
