Thread: narrowed 9 inch
Old 07-16-2002, 02:46 PM
gman gman is offline
Cobra Make, Engine: A&C 460
Roscoe, nice to here from you. I've checked out your build site when I searched the forums for A&C. Nice car. You helped me make up my mind on whether to press new bearings on my axles. they didnt put the disc brake spacer on first and I didn't want to cut them. Could you give me more info on the adjustable bars? I'm not real crazy about the pinion angle either. Also they have the shock brackets parallel with the housing face and the steep pinion angle causes the coil overs to rub on thir own bracket Thanks,Gman
