Old 07-19-2002, 08:35 AM
Back in Black's Avatar
Back in Black Back in Black is offline
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Lightbulb You also need to:
Store it in a heated garage, hopefully. If it is not heated, be sure to keep the top on, and a BIG pack of dessicant in the cockpit, rotate it regularly, or you will get mildew, etc..
Change the oil and filter, then drive it only as needed to get it into the garage, and or to start it once in a while.
Put PRI-G gas preserver in the tank
Get a maintainence type battery charger, put the battery on a shelf, NOT in the trunk, also NOT on a concrete floor, and keep the charger constantly attached and plugged in...they are available thru any good motorcycle or auto specialty shop, I use the "Battery tender" brand. ($35.00)
Wash, wax, and use a good car cover before storage.
Keep your tires inflated correctly
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
