K...
I know all the hype, sat in almost every make of Cobra, except a JBL...gotta find a JBL, and bottom line, I haven't found one yet that has as much "footwell" as "Roadsters." You might give serious thoughts, even with a Roadsters car to go with an automatic. I know, I know, but with today's "slush boxes", bottom line is they are usually stronger and definately faster.
Struts: I'm going to take a beating on this, but, I think strutless is more hype than anything. We build many streetrods, and I think this is where the "strutless look" came from. (I know it is)
If you really, really want to get "trick" on this, throw away the "Fixed" strut rod and replace with one that is set up with a heim joint type end. Absolutely eliminates any binding, and IS fully adjustable for those that have to be able to adjust everything!
DV -- Let the Flames begin!
