Old 07-22-2002, 08:05 AM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
Check the switch, if it's not hooked up right you will get exactly what you are describing. Let me know what type of headlight switch you have, specifically if there is a terminal bar across any of the terminals. If the back of the switch is open with 6 lugs it wires different than the manual tells you.
Don
