Old 07-23-2002, 03:33 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
Rodney,
I tried faxing you a drawing but it didn't go through. Is that fax number correct? Was it turned off at about 1 pm PST? Anyway the pointer is simple to make, no need to accurately copy anything. You just need a fixed "tab" that hangs out next to the dampner. You will draw your own "timing mark" after finding true TDC with a piston stop.
