Old 07-24-2002, 04:45 AM
Mike Hausner Mike Hausner is offline
Club Cobra Member
Cobra Make, Engine: CLASSIC ROADSTERS 427 with a FORD 5.0 bored and stroked to 331cid, BRODIX alum heads, roller rockers, B303 cam.
Default Fuel System Questions
WHERE IS THE BEST PLACE TO MOUNT MY ELECTRIC FUEL PUMP?
I am thinking of mounting my CARTER electric fuel pump in the space between the fuel tank and the frame on the passenger side. The pump inlet will be 4 or 5" above the bottom of the tank and will have about 28" of line to the tank outlet. I WAS also going to use a FRAM cartridge filter between the tank and pump, but it is pretty big and hard to package. It's probably overkill for my setup anyway. What kind of filter should I use?
I'm also going to re-rout the 3/8" fuel line down the passenger side since I'm not using an engine driven pump. This will give me a more direct line to the EDELBROCK carb. How does this set up sound ?
I think by the time this project is done I'll have enough left over parts to build another car !!
