Old 07-24-2002, 05:47 AM
Double Venom's Avatar
Double Venom Double Venom is offline
Mike,
Sounds exactly like the way we install ours. Use a large filter from Jegs or Summit. If you have installed the steel "L" or 3" angle between the rear frame rails for your 4-point seatbelts, then you can hang the pump and filter from it.
Sounds like you are making good progress!
DV
