Old 07-24-2002, 09:00 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
Your disk is a McLeod. There is a roller pilot shaft bearing available, I don't have the part #. Check your bellhousing to crankshaft alignment, you may need to correct with offset bushings, don't worry about the appearance of the flywheel unless it is really groovy or blue.
