Pioneer : CA-3015 about $9.00
The cable I listed above will work with Tremec 3550, tremec TKO, and toploaders. The 90 degree adapter gearbox for reverse sweep speedo's is separate. I don't have that part number, but Stewart Warner makes the good one (about $25). The gear you put on the end is different for Tremecs vs. toploaders. Tremec's have RH pitch, toploaders have LH pitch.
