Old 07-24-2002, 06:38 PM
Jerry Cowing Jerry Cowing is offline
gobu,
I'd also pre-oil the engine before you fire it up. Two methods: 1) insert a distrubutor rod into the distributor hole and slowly turn it with an electric drill (medium speed) until you see oil on your valve rockers. 2) Disconnect the positive wire from your coil and turn the engine over until you see the oil gauge needle move. Reinstall the coil wire and then start the engine using the above procedures the guys recommended.
Jer
