Old 07-24-2002, 06:49 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Door stops screw in/out, and have rubber tips on ends.
Many brackets made from Stanley shelf brackets, then bent, drilled, tapped, etc.
Muffler clamp holds steering column by firewall.
Most CR hardware replaced with G8 for strength, or stainless for corrosion resistance.
Hope your CDMV inspection doesn't flunk you for wrong color rear turn signals. In the Peoples Republic of New York, a guy flunked inspection because the lenses didn't have the DOT number on it.
It's always the little stuff that drives you up a wall.
