Thread: FE Misfire
Old 07-24-2002, 08:54 PM
Bruce Botti Bruce Botti is offline
Default FE Misfire
Hello to all. I've got a question for you FE experts. I've got a 406FE from Southern Automotive with iron heads, aluminum intake, Holley 750cfm carb, turkey pan, and a Crane fireball ignition box and coil.
I've had problems with it misfiring. I readjusted the accelerator pump and it now accelerates fine, but if you are just loafing along, it misfires. The timing is set for 36-38 degrees advanced at 3000rpm (about 12 at idle). It starts instantly and idles smoothly. The plugs look as if it is running a bit lean (the color is between white and tan). Where else should I look?
Thanks in advance,
Bruce
Bruce Botti
Botti Enterprises
www.cobra427.iwarp.com
