Old 07-27-2002, 09:33 PM
Double Venom's Avatar
Double Venom Double Venom is offline
Ron,
Explain a little further please? If you have the CR harness you should have the engine harness. If not you can order it from CR's.
Headlight harness plugs into what could be considered the "back" of the Fuse block. Paul is right...the fuse block on a CR's is mounted through the firewall, fuses facing the driver, main harness' coming out the back, or engine side. This is where the headlight harness, as it's called will plug in.
Sounds to me like you only have about a 1/3 of the harness???
DV
