Old 07-28-2002, 06:10 AM
Double Venom's Avatar
Double Venom Double Venom is offline
Ron,
If I'm thinking correctly, and it's early Sunday AM, the fuse block side of the headlight harness has a large black connector with two ears coming off of it. Sort of like a thin legged, thick bottomed "U".
If you've mounted the fuse block the same as CR's does, and I remember right, it will be the second harness you will attach. the "U" will face left, with both of the legs holding in the first connector.
I will try and get my camera program set up for this computer today and see if I can't get you some pictures.
DV
