Old 07-29-2002, 10:15 AM
Shaun Shaun is offline
Question Drive shaft alignment
Cannot seem to get a straight answer on this question. What is/are the proper alignment "angles" of the rear pinion to the engine that will limit U joint wear?? I have heard things like, the pumpkin needs to be about 3-4 degrees down angle and the engine needs to be about the same. Also heard they should be "parrallel" to each other. Can anyone give me the "right " answer backed with some facts?? MUCH APPRECIATED!!
