No. its actually the other way around.
Steel crank is more rigid, but that does not necessarily mean better. If you live at 7000 all day maybe a slight advantage. Steel, ostensibly is stronger and can spin higher, but this does not necessarily play out in the real world.
Cast gives a little more. Either one is fine for most applications.
As an example, 427s came w/ steel cranks; other FEs like 428 had cast. I believe all Windsors came w/ cast.
Bill Malone
Gashole
CSX4786
