Thread: Engine knock
Old 07-31-2002, 05:34 PM
SuperHart's Avatar
SuperHart SuperHart is offline
Cobra Make, Engine: Cobra Fibercraft Bodies 427 S/C, 351W disguised as a 427.
Send a message via AIM to SuperHart
Several things need checking. First, what weight oil are you using? Too light may result in lower oil pressure. Also, certain oil filters create too much back pressure resulting in low oil pressure in the engine. Also, are you running oil cooler line or a remote filter?
A knocking sound may be caused by an underpressurized or sticking hydraulic lifter OR perhaps a connecting rod wrist pin fitted too sloppily in its piston. A sloppy wrist pin will knock when cold and disappear when the motor is hot. At any rate it sounds like you have tome serious diagnostics to perform before the entire motor waves bye bye. Good Luck.
Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
