Old 08-01-2002, 12:35 PM
Back in Black's Avatar
Back in Black Back in Black is offline
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Cool Two ways of looking at it
#1) If you use the car only locally, and it does not overheat, you don't need it
#2) if you plan on touring or other activities that may get you into hot(ter) conditions, then install one with an oil temp thermostat...this allows flow only above a certain oil temp. be sure to drain the oil in the cooler and lines when doing an oil change.
BiB
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
