Old 08-01-2002, 02:26 PM
Dan Stryffeler Dan Stryffeler is offline
Cobra Make, Engine: Everett-Morrison, 347 Tri-power Stroker
Last summer, w/o a cooler, I was running about 230 degrees on the highway. The temperature probe was inserted via a spacer in the line to the remote oil filter.
Installed a cooler over the winter and rerouted the probe to the back of the oil pan (a baffled Canton). The oil typically runs about 160 degrees at highway speed. I blocked off the cooler with duct tape and ran it again - no change in temp, (which IMPLIES that a thermostat might not make any difference).
I'm not sure if I'm comparing apples to apples since I changed the location of the temp. probe. Go figure....
With the baffled pan, maybe I'm taking the temp from a 'dead' spot?
Dan
