Tubular Front Susp
Although I have coil over shocks I don't have tubular front upper and lower A-arms. I still have the basic stamped Mustang II front susp. However, I have noticed a bit of a rub on my upper ball joints bolts and inside my tire rim. Nothing very serious but it is creating a nice shjine on one of my ball joint bolts the inside of my rim.
I want to know if all the after market front tubular A-Arms are basically the same for a Cobra application or are there some better than the others? Which would you recommend? I want to get mine changed out before Run and Gun. In checking I have found prices for both upper and lower fronts range between $400 (Shell Valley) and about $700. Any input would be greatly appreciated.
Thanks.
"Let's roll"
"Be part of Something Good
