I'm not starting any bidding war, just cleaning out the garage of unused parts. I oughta put up another list.
jwinkler, there's a reason the old 351-ized motor & frame mounts are in the box, and the new style are in the car (and working quite well). If you can get CR, Don, or DV to part with a pair of their new style frame mounts that uses late Mustang motor mounts with the 14mm bolt, you'll only have to install them once. Use Energy Syspension urethane motor mounts and trans mount.
There is no bargain to it if you have to do it over again, and motor mounts are a mutha to put in a car with the engine already installed. And making a buck isn't worth loosing a friend.
If, none of the above are using the new late Mustang style mounts, I'll dig out my drawings and have a few sets made for you guys. The difference is quite dramatic.
Don makes some mildly powered Cobras that wouldn't be debilitated with soft motor mounts.
Don, send me your e-mail. I have some other leftovers you might be able to use.
