Old 08-04-2002, 06:15 PM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
Default No big deal
I have done this switch on a 69 Mach I several years ago and it is really not much effort at all. Go to the salvage yard and pull off the brake and clutch pedals and all the hardware ie: clutch linkage, t/o brg lever etc. Of course you could put a hydraulic t/o bearing in place of the conventional one . You will need to pick up a pilot bearing ($15) and a good flywheel, clutch, PP. and throw out bearing. The trans mounts are the the same and the correct shifter hole (if I recall) is already marked by Ford and just needs to be cut out w/ a jig saw. Drive shaft length should be the same althought you probably have 308 gears in the rear end now. You may want to pick up another pumpkin w/ 325 or 350 gears.
Lets see about $300 for a good clutch and pressure plate assy, then about $200 for a flywheel, and you will probably spend about $20 at the salvage and then what ever you are going to pay for your trans and bell housing.
Find someone with a standard in there Torino, Mustang, Galaxie, or Fairlane that wants to put in an automatic and trade as much as you can. Good luck.
"Let's roll"
"Be part of Something Good
