Old 08-05-2002, 04:25 AM
Frank Coppola's Avatar
Frank Coppola Frank Coppola is offline
What is a helicoil?
I pulled the oil pump yesterday and took it apart. It was NOT the spring in the pump. Yes DV, that would have been a good trick if that was it. The piece of spring I found was a bit larger in diameter than the check valve spring in the oil pump. My builder said he did not use a spring in front of the cam shaft.
Craig, I'll check the sandwich plate.
Frank Coppola
___________________________________
"Gunga Galunga... gunga, gunga-galunga."
