Old 08-05-2002, 08:18 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
The "clunking" is normal, there are 6 U-joints and the backlash on the ring and pinion gear all right there for you to hear. As far as the disk brake squeal, just get some of the "disk brake quiet" spray glue and attach the pads to the pistons. The willwoods don't have spring clips to keep the pads from chattering around in the calipers.
