Old 08-05-2002, 01:26 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
Also,
Often the original installer doesn't get the calipers shimmed properly to keep the caliper's and rotor's axis parallel. Willwood's come with a bunch of really thin washers used to shim the caliper into proper alignment with the rotor. Not sure if this would effect squeaking or not, but one more thing for you guys to look at when you have your heads down there.
