Old 08-05-2002, 05:00 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
I always had fine luck with the March underdrive pulley sets on 460's. No overheating problems even on showqueens that almost never get past first gear. Moving water faster doesn't hurt, but the most important thing in a cooling system is to exchange heat and that's the job of the radiator and fans. Don't forget the need for a rad cap that holds pressure, a worn out rad cap can cause heating problems.
