Old 08-07-2002, 06:56 AM
Maury Novak Maury Novak is offline
Cobra Make, Engine: Classic Roadsters, 302 (modified)
Question Classic Roadsters Electrical Problem
I have just developed a problem of having power to the starter solenoid when the ignition switch is ON. I have checked the starter solenoid and the ignition switch, and both appear to be ok.
Is there a RELAY under the dash that provides power to the solenoid? I went through the manual and I can't find an mention of that particular relay. I have not yet squeezed under the dash. I have had my car together since '95. I am using the standard CR wire bundles but have an ignition switch/steering column out of an '85/'86 Capri. I have had no electrical problems until now.
Thanx for the input.
