First: Make sure that the alt is grounded VERY well. Use a test light and check for power at the input terminal of the alternator. If power is there, hook a jumper wire between the 2 terminals on the voltage regulator marked B and F run the car and CAREFULLY check for power. If power is there when you charge the field terminal, you have a bad regulator. If no power there at all, a bad alternator. If you have power when you jump but not without the jumper, you have a break in the field wiring circuit. THIS PRESUMES THAT YOU ARE USING A FORD VOLTAGE REGULATOR AND THE OLD STYLE FORD ALTERNATOR! Any other questions, post and I will go thru more details with you. If you are running an idiot light, check to make sure its wiring is not broken as well.
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
