  #23 (permalink)
Old 08-07-2002, 03:30 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
The oil stays in the cooler, if it drained out then there would be a dry start every time you fired up the motor. You could drain the cooler and then prelube the motor before fire-up every time but who would. So you only change 5 out of the 6 quarts of oil in there, big deal, close enough. You can never get all the dirty oil out anyway, it still coats all the internals.
