Old 08-08-2002, 06:22 AM
aumoore's Avatar
aumoore aumoore is offline
Cobra Make, Engine: Hunter 427, 5.0 (302)
to the top
I am not getting any readings on my SW gauge. When I ground the wire that goes to the sender the gauges goes all the way to the top so I doubt the gague is the problem. It could be how I mounted the sending unit. It is mounted in a T-fitting next to the oil pressure sending unit. This places the sending Unit about 4" from the engine block but it still has oil on it. Should I reroute it to the Oil pan and if so should I mount it in the oil drain hole. I am running a 5.0 with a double sump Fox Mustang oil pan so I was thinkng of using the rear oil drain hole as it is higher than the rear.
Any thoughts
Click here for DSCC website
