Old 08-08-2002, 08:31 AM
wilf leek's Avatar
wilf leek wilf leek is offline
Cobra Make, Engine: Crendon, windsor 408 stroker, tremec. Also GSX008
aumoore - have had many a discussion with folks here in the UK about mounting oil temp senders in the pressure take off "T".
My view is that this will not give a true reading, as the sensor is in a dead leg - no oil flow past it, so it cannot sense true bulk oil temp.
Test the sender with the boiling water method to make sure it's OK and to calibrate your gauge, and then relocate it somewhere where it can "see" the true oil temp - you may find in the pan is OK, but again I have seen "dead spots" there as well.
If you have a remote oil filter, getting into one of the lines either to or from that would be good.
HTH
Wilf
