Old 08-09-2002, 12:06 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
So you attach the gearbox to the speedometer, then attach the cable to the gearbox, perpindicular to the input on the speedo? What speedo do you have? It is mechanical right? Right to left sweep? The gearbox is not straight through, the input and output are 90 degrees from one another, right?
