Old 08-09-2002, 10:29 PM
Back in Black's Avatar
Back in Black Back in Black is offline
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Exclamation The shorter it is...
The more power it has to punch thru the FIBERGLASS and take your hip out, if a u-joint breaks......do please consider some type of heavy sheet STEEL shield...
This is one reason I like the West Coast...all steel double layer pan and heavy duty shield on the driveline section
A strap is not going to work well on a short shaft behind all that HP, if things go south
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
