Pre-lune the system first. Then before you start it, crank i t over with the ignition off till you see pressure on the gage. After it starts, bring the rpm up to 2,500 and let the cam break in for 20-30 minutes. Good luck.
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
