Old 08-12-2002, 07:04 AM
jams's Avatar
jams jams is offline
Cobra Make, Engine: B & B
Keep a wet rag handy to throw over the carb in the event you have any flames. It puts out the fire and does not make as much of a mess as a fire extinguisher.
If you have an electric fuel pump, let it build up pressure to check for leaks before cranking the engine.
Good luck
Just enough knowledge to build a cobra and be dangerous...
You can observe a lot from just watching.
