Tim,
I suppose if you run with 37mm choke is for road use.About power Ithink the only thing to do to get power is to go on a dyno (not rolling dyno),personnally Ifind 45HP difference between 32 and 38°.155 on main jet is current with your combo but with your air corrector is certainly to lean at top end,try in the 155/165 range,let me konw ,regards,Bernie
Bernie 289 FIA
