Old 08-12-2002, 09:30 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
SPF's often do this between 65 and 70 mph. Goes away after that. And it only happens on the freeway, not surface streets. I have pondered that it was becuse the ripples on the freeway expansion joints were hitting the tires one before the other, causing an occilation back and forth. Just guessing as to the cause.
