Old 08-13-2002, 01:00 PM
ronzara's Avatar
ronzara ronzara is offline
Cobra Make, Engine: Everett-Morrison 351w assembly STILL in progress
Send a message via AIM to ronzara Send a message via Yahoo to ronzara
Default Ford Engine Harness Install ?'s
I am installing the CR Ford Engine Harness,... I have found many things are not used. I am using the Stewart Warner Cobra Gauge set, which are mechanical gauges. Only Fuel gauge uses a sender as far as I know.
The Engine is a 1973 351W, It has 4-pole Alternator:
The engine has NO ECM unit.
Distributor has 1 wire coming out of it. It runs to the COIL NEG (-) . I am assuming I don't need an ECM unit. Is this right ? If so, what do I do with wires 185, 186, 187 ??
I have connected the COIL POS (+) to Harness wire 138. Manual Says to attach #132 toCOIL NEG (-), Should I splice this in with the wire from the Distributor ?
My Voltage Regulator has 4 prongs:
F - I have attached #115
S - I have attached #119
A - didn't know about this one, Is this #109 ?
I- didn't know about this one, Is it #180?
110 is connected to BAT side of circuit Breaker, 111 & 112 to the AUX side of the same breaker.
WHAT ATTACHES THE TO OPPOSITE SIDES OF THESE BREAKERS ?
Do I need a Ballast resistor? If so, Any suggestions on which one?
Thanks for all your assistance guys. With any luck, I'll still have a few hairs left on my head when I get this car on the road! : )
RZ
Ron Zara
ronzara@hotmail.com
1. "Putting a Chevy Motor in a Shelby Cobra is like CUSSING IN CHURCH!"...... ME
2. "Friends Don't Let Friends Drive Junk"....
