Old 08-14-2002, 08:42 AM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
RZ, I'm assuming you are running a points distributor since you only have one wire. This wire will hook to the neg. side of the coil with wire # 132.
Wire #128 hooks to the pos. side of the coil. You will need to hook up a ballast resistor. Wire #138 and #128 go to the ballast. Use a standard Ford ballast from any year Ford with points.
The alternator wires are correct as you have them.
There are only three wires to the breaker. #110 is power in #111 and #112 are power out.
The other wires 185,186,187 are for the electronic ignition. You can tape, cut, or do whatever you want with them.
Don
