Old 08-14-2002, 10:39 AM
Jim Werth Jim Werth is offline
Cobra Make, Engine: B+B 351w #112
Are you sure you have a limited slip rear end. Bet the one that spins is the passenger side. Or maybe you need to replace the clutch pack in the rear end. Jack up rear of the car so both tires are off the ground. Put in neutral. Spin one tire froward. If the other tire spins backwards you do not have a limited slip rear. If they both spin forward you do. Jim
