Old 08-14-2002, 03:35 PM
427sharpe's Avatar
427sharpe 427sharpe is offline
Cobra Make, Engine: A CSX Cobra,1966 GT350 and an '06 Ford Heritage GT
You can fix an oil cooler just like a radiator, find the leak and solder it shut. To avoid future leaks, try not to blip the throttle @ startup, as this creates a very high pressure spike that can create a leak. I found this out from Earl's, when I sent my first oil cooler back for warranty after it developed a leak. I added a bypass thermostat, but Earls makes a check valve that will shut off flow at very high pressure loads. Try www.amstreetrod.com for an quote.
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
