Old 08-15-2002, 07:32 AM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
RZ, Yes the #132 does wire to the coil with the dist wire. That is proper hookup for the tach. Doesn't matter which side of the ballast the wires go to, it's just a big resistor.
What type and brand of fan do you have? I haven't seen one with 3 wires.
The breaker supplies main power to the fuse block so no other wires hook to this. The starter and solenoid draw power direct from the battery. The fuse block supplies power to the control wire on the solenoid. The Breaker is actually 2 30 amp breakers tied together to supply a 60 amp circuit.
Don
